    Unable to access to the aplication
    18 Posts 2 Posters 6.4k Views 1 Watching
      Russ @gabi92a
      @gabi92a, what country are you in?
      I wonder if there's some sort of firewall or proxy server between your computer and the TRIGGERcmd servers that's preventing the token login.
      It's strange though because I looked at the code and it's a pretty straight forward request:
      function tokenLogin(token,callback) {
        // Configure the request
        headers.Authorization = 'Bearer ' + token;
        options.headers = headers;
        options.url = urlprefix + '/api/command/list';
        options.method = 'GET';
        // Start the request
        request(options, function (error, response, body) {
          if (!error && response.statusCode == 200) {
            writeNewTokenToFile(token);
            callback(token);
          } else {
            console.log('Token login failed.');
      I tried your token and it worked for me - it created a computer in your account. I deleted it afterward.
      Also, I removed your token from your post so other people can't create computers in your account, or trigger your commands once you get this working.
      • G Offline
        gabi92a
        Im in Spain, Barcelona. I added the application to the firewall rules, but is making the connection in port 80 right?
        • G Offline
          gabi92a
          I will try to using a vpn or something like that, and lets see if i have differences with another range of ip
            Russ @gabi92a
            @gabi92a, good luck. Do you know if Spain has some sort of country wide firewall? Like China? I doubt it, but I thought I'd ask.
            Also, the agent connects to https://www.triggercmd.com over port 443.
            • G Offline
              gabi92a
              Is a bug in the application. I used fiddler for see what is happening in the call, and the application is sending nothing.
              I have the ports unlocked, because if not i cant use the https protocol, and my country dont block anything.
              I think that is something about the language of the computer, that is making a error in the application. You are losing money because that.
              Regards.
                Russ @gabi92a
                @gabi92a, that's a good idea. It could be the Spanish language on the computer. If so I'm sure I can solve that because I should be able to reproduce it by switching my computer to Spanish. Thanks for that idea.
                EDIT: I tried it - I installed Spanish language on my Windows 10 box and set my region to Spain. Unfortunately it still works for me.
                Are you using Windows 10?
                BTW, I appreciate you not giving up. I really want to solve this. Like you said, I'm loosing money.
                  Russ @gabi92a
                  @gabi92a, would you be willing to try this? This will run the agent without the GUI. I suspect the bug is in the GUI.
                  1. Install NodeJS
                  2. Open a cmd prompt
                  3. Run this: node %userprofile%\AppData\Local\TRIGGERcmdAgent\app-1.0.21\resources\app\src\agent.js --console
                  • G Offline
                    gabi92a @Russ
                    @russ Token login failed using the console 😞
                      Russ @gabi92a
                      @gabi92a, thank you for testing. That narrows it down. I created a branch with updated dependencies for you to test (if you're willing). I'm hoping this solves the problem.
                      • Create a folder on your 😄 drive
                      • Open a cmd window, and cd to that folder.
                      • Install git if you don't already have it.
                      • Run this:
                        git clone -b spain https://github.com/rvmey/TRIGGERcmd-Agent.git
                      • cd into the TRIGGERcmd-Agent subfolder.
                      • Run this:
                        npm install
                      • Run this:
                        node src\agent.js --console
                      • Paste in your token
                      If that works, then I believe I can produce a new version that will work on spanish Windows computers.
                      • G Offline
                        gabi92a
                        @russ said in Unable to access to the aplication:
                        Weird error installing: https://gyazo.com/e769546f7621fda85951352a2223a47b
                        Result failed inserting the token: https://gyazo.com/8dfc9f27f419c3a100a7078a7cb843eb
                        Regards.
                          Russ @gabi92a
                          Thanks @gabi92a, that's helpful, but I should have added some debugging output.
                          I added these lines:
                            console.log("Response from server:");
                            console.log(response);
                            console.log("Error from request:");
                            console.log(error);
                          Please try this updated code with these steps:
                          • Open a cmd window, and cd to that c:\TRIGGERcmd\TRIGGERcmd-Agent folder.
                          • Run this:
                            git pull
                          • Run this:
                          Also, it looks like you ran node install.js instead of npm install. What does that do?
                          • G Offline
                            gabi92a @Russ
                            Result: https://gyazo.com/afe127ffd8783f80a4f1e11b09bb4da5
                            No, i ran the npm install.
                            Regards.
                            • G Offline
                              gabi92a
                              Is an error 400, but im not seeing nothing in fiddler, there is no call???? 😞
                                Russ @gabi92a
                                @gabi92a, I found out why Fiddler wasn't working. For NodeJS apps like the TRIGGERcmd agent, you have to set these environment variables before you run the node src\agent.js --console command:
                                set https_proxy=http://127.0.0.1:8888
                                set http_proxy=http://127.0.0.1:8888
                                set NODE_TLS_REJECT_UNAUTHORIZED=0
                                That tells the NodeJS app to use Fiddler as a proxy server.
                                I found that here: https://weblogs.asp.net/dixin/use-fiddler-with-node-js
                                Can you try that? Maybe that will give us a clue.
                                Also, you could try running it after setting this variable to get a bunch of debug output:
                                set NODE_DEBUG=*
                                One thing you should know - the agent uses a websocket to connect to the server, and that connection doesn't use the https_proxy variable so Fiddler won't pick that up. The request that's giving us this error doesn't use websockets though, so that shouldn't matter for this troubleshooting.
