Unable to access to the aplication
Is happening the same here: https://www.triggercmd.com/forum/topic/420/agente-de-windows-en-el-sign-in-no-funciona
@gabi92a, what country are you in?
I wonder if there's some sort of firewall or proxy server between your computer and the TRIGGERcmd servers that's preventing the token login.
It's strange though because I looked at the code and it's a pretty straight forward request:
function tokenLogin(token,callback) { // Configure the request headers.Authorization = 'Bearer ' + token; options.headers = headers; options.url = urlprefix + '/api/command/list'; options.method = 'GET'; // Start the request request(options, function (error, response, body) { if (!error && response.statusCode == 200) { writeNewTokenToFile(token); callback(token); } else { console.log('Token login failed.'); } }) }I tried your token and it worked for me - it created a computer in your account. I deleted it afterward.
Also, I removed your token from your post so other people can't create computers in your account, or trigger your commands once you get this working.
Im in Spain, Barcelona. I added the application to the firewall rules, but is making the connection in port 80 right?
I will try to using a vpn or something like that, and lets see if i have differences with another range of ip
@gabi92a, good luck. Do you know if Spain has some sort of country wide firewall? Like China? I doubt it, but I thought I'd ask.
Also, the agent connects to https://www.triggercmd.com over port 443.
Is a bug in the application. I used fiddler for see what is happening in the call, and the application is sending nothing.
I have the ports unlocked, because if not i cant use the https protocol, and my country dont block anything.I think that is something about the language of the computer, that is making a error in the application. You are losing money because that.
Regards.
@gabi92a, that's a good idea. It could be the Spanish language on the computer. If so I'm sure I can solve that because I should be able to reproduce it by switching my computer to Spanish. Thanks for that idea.
EDIT: I tried it - I installed Spanish language on my Windows 10 box and set my region to Spain. Unfortunately it still works for me.
Are you using Windows 10?BTW, I appreciate you not giving up. I really want to solve this. Like you said, I'm loosing money.
@russ Token login failed using the console
@gabi92a, thank you for testing. That narrows it down. I created a branch with updated dependencies for you to test (if you're willing). I'm hoping this solves the problem.
- Create a folder on your
drive - Open a cmd window, and cd to that folder.
- Install git if you don't already have it.
- Run this:
git clone -b spain https://github.com/rvmey/TRIGGERcmd-Agent.git - cd into the TRIGGERcmd-Agent subfolder.
- Run this:
npm install - Run this:
node src\agent.js --console - Paste in your token
If that works, then I believe I can produce a new version that will work on spanish Windows computers.
@russ said in Unable to access to the aplication:
Weird error installing: https://gyazo.com/e769546f7621fda85951352a2223a47b
Result failed inserting the token: https://gyazo.com/8dfc9f27f419c3a100a7078a7cb843eb
Regards.
Thanks @gabi92a, that's helpful, but I should have added some debugging output.
I added these lines:
console.log("Response from server:"); console.log(response); console.log("Error from request:"); console.log(error);Please try this updated code with these steps:
- Open a cmd window, and cd to that c:\TRIGGERcmd\TRIGGERcmd-Agent folder.
- Run this:
git pull - Run this:
Also, it looks like you ran node install.js instead of npm install. What does that do?
Result: https://gyazo.com/afe127ffd8783f80a4f1e11b09bb4da5
No, i ran the npm install.
Regards.
Is an error 400, but im not seeing nothing in fiddler, there is no call????
@gabi92a, I found out why Fiddler wasn't working. For NodeJS apps like the TRIGGERcmd agent, you have to set these environment variables before you run the node src\agent.js --console command:
set https_proxy=http://127.0.0.1:8888 set http_proxy=http://127.0.0.1:8888 set NODE_TLS_REJECT_UNAUTHORIZED=0That tells the NodeJS app to use Fiddler as a proxy server.
I found that here: https://weblogs.asp.net/dixin/use-fiddler-with-node-jsCan you try that? Maybe that will give us a clue.
Also, you could try running it after setting this variable to get a bunch of debug output:
set NODE_DEBUG=*One thing you should know - the agent uses a websocket to connect to the server, and that connection doesn't use the https_proxy variable so Fiddler won't pick that up. The request that's giving us this error doesn't use websockets though, so that shouldn't matter for this troubleshooting.
