    Run an XML File located on Cloud
    Instructions
    b b
    • M
      Muvvala G
      Hay,
      i just setup the TriggerCMD on one of my machine and i jst want to know is there ny way to run an xml file which will trigger set of JAVA classes, my requirement here is if the file is in my local machine i can run that using a .BAT file, but if it hosted on GITHUB and execute from JENKINS, then it comes to the problem.
      Can you please assists me on this how can i achieve,
      1) Running an XML on local machine is workig fine with the .bat file
      2) Now, the XML file hosted in GitHub and execution is linked to Jenkins, now i
      need to run that Jenkins Job with Alexa
      3) Can you please help me on this
      One of my main concern here is JENKINS or any other Cloud is Authentication based (Username and Password), so can Alexa will execute that and how can we achieve that using TriggerCMD
      Thanks,
      Gouri
        Russ @Muvvala G
        @muvvala-g, I use Jenkins too, so I can put together an example if you want, but here's some quick research I did so far:
        https://jenkins.io/doc/book/managing/cli/#common-commands
        It looks like Jenkins gives you a command-line tool that can run jobs.
        EDIT: I tried it out and it works pretty well. My command looks like this:
        java -jar jenkins-cli.jar -s http://localhost:8080 -http -auth admin:PASSWORD build MyJob -v -s
        Also, I downloaded the jenkins-cli.jar from my own Jenkins server with this command:
        wget http://localhost:8080/jnlpJars/jenkins-cli.jar
        Does that accomplish what you're trying to do?
