    2. Muvvala G
    M Offline
    Muvvala G
    @Muvvala G
    Muvvala G Unfollow Follow
    • Run an XML File located on Cloud
      Hay,
      i just setup the TriggerCMD on one of my machine and i jst want to know is there ny way to run an xml file which will trigger set of JAVA classes, my requirement here is if the file is in my local machine i can run that using a .BAT file, but if it hosted on GITHUB and execute from JENKINS, then it comes to the problem.
      Can you please assists me on this how can i achieve,
      1) Running an XML on local machine is workig fine with the .bat file
      2) Now, the XML file hosted in GitHub and execution is linked to Jenkins, now i
      need to run that Jenkins Job with Alexa
      3) Can you please help me on this
      One of my main concern here is JENKINS or any other Cloud is Authentication based (Username and Password), so can Alexa will execute that and how can we achieve that using TriggerCMD
      Thanks,
      Gouri
      posted in Instructions b b
      M
      Muvvala G
