    Smart reply for voice with parameters
    13 Posts 5 Posters 5.4k Views 2 Watching
    • M Offline
      MysticNynja
      Just was wondering if there is a way to have a voice reply for different parameters sent in.
      Let's say I have a batch that can accept on, off, or no parameter. It would be cool to have the reply say something different for each one of these situations.
      "Ok Google, Ask TriggerCMD to run Plex with parameter on"
      Voice Reply: Turned on the plex server
      "Ok Google, Ask TriggerCMD to run Plex with parameter off"
      Voice Reply: Turned off the plex server
      Plex.bat
      if "%1"=="on" "Plex Media Server.exe"
      if "%1"=="" "Plex Media Server.exe"
      if "%1"=="off" taskkill /IM "Plex Media Server.exe"
      Now I can just have two different triggers and call the correct one for on/off control but I also have smartthings and have them hooked up there. The Device Handler for that is defaulted to a switch with on/off states. If I have two Virtual Switches on Smartthings I think that could get very confusing. I think I can modify the DTH to be a button or something, but I like the idea of a state being reported to my screens.
      Anyway short of it is is there or can we have a way to have a more intelligent reply based on what parameter is passed in.
      Thanks!!! Having a blast with this, can't wait to subscribe so I can really have fun with it πŸ™‚ Just have to wait until after christmas, every dollar counts!
        Russ @MysticNynja
        @mysticnynja, that's a good idea, and I don't think it would be too difficult. I'd have to let you put a placeholder like {{param}} in the voice reply field. I'll add this to my todo list.
        coleglC 1 Reply Last reply Reply Quote 0
        • coleglC Offline
          colegl @Russ
          @russ
          Did this ever get implemented? It would be useful to me.
            Russ @colegl
            @colegl, thanks for the reminder. I did it just now, and it's awesome!
            @mysticnynja, thanks for the suggestion.
            Now you can use these placeholders in your Voice Reply field:
            • {{trigger}}
            • {{computer}}
            • {{params}}
            • {{result}}
            Voice Reply Placeholders
            • M Offline
              MysticNynja
              I just saw this!! Awesome I'll try it out today and let you know!
              • S Offline
                Sim Wonkdonk
                Can I ask a follow up question?
                I'd like to have editable voice response too, and I'm running triggercmd on pi, I assume it would be a case of updating the installation and editing the json file (I have no ui on my pi).
                I'd actually like to be able to disable any feedback at all, currently it says "Getting triggercmd" and then "blah blah blah on pi"
                  Russ @Sim Wonkdonk
                  @sim-wonkdonk, you could minimize the response by putting a space in that voice reply field.
                  • S Offline
                    Sim Wonkdonk
                    I'm using a raspberry pi, so I have to edit the commands via the commands.json
                    {"trigger":"STANDBY","command":"/opt/TIVO/ircode-script.sh STANDBY","ground":"background","voice":"STANDBY","allowParams": "false"},
                    Putting a space in the "voice" parameter stops the command work, as thats the trigger word for the command, not the response the command gives.
                    I guess there's no work around?
                      Russ @Sim Wonkdonk
                      @sim-wonkdonk, the voice field is different from the voiceReply field. Your example is missing the voiceReply field.
                      Here's an example with that field:
                        "trigger": "test command",
                        "command": "d: & cd \\appdev\\test & node t.js",
                        "ground": "background",
                        "voice": "test",
                        "voiceReply": " ",
                      • P Offline
                        Phil Tanguay @Russ
                        @russ related to this - is it possible to include the script output in the voice reply ? For example - current lab temperature is {{result}} celcius.
                        Just started using triggercmd and it’s fantastic - great service mate, we’ll worth the $ !
                          Russ @Phil Tanguay
                          @phil-tanguay, I do plan on implementing that ability soon, now that I've added the SendResult script to the .TRIGGERcmdData folder to send a result of a command back to the server.
                          Currently the result just gets logged in the Runs log for the command.
                          It's on my todo list.
                          • P Offline
                            Phil Tanguay @Russ
                            @russ Awesome ! Looking forward to it but no rush πŸ™‚
                            My brain is bubbling with ideas - triggercmd has opened a whole new avenue for cool automations.
                              Russ @Phil Tanguay
                              @colegl and @phil-tanguay, I implemented this today for Google Assistant. I'm working on Alexa now.
                              I put this in my Voice Reply field of my Notepad command (I should have just created a new command):
                              Running {{trigger}} on {{computer}} with params {{params}} with result {{result}}
                              I put this in the Command field:
                              %USERPROFILE%\.TRIGGERcmdData\sendresult "My command result"
                              I said this:
                              Ask trigger command to run notepad with parameter russ
                              Google Assistant said this:
                              Running notepad on DS with params russ with result My command result
                              I'm pretty happy with how it turned out.
                              I only gave about 4-5 seconds to send a result via that SendResult.bat script. If you take too long, it will say "no result" in the {{result}} placeholder.
                              EDIT: Now you can do this with Alexa too.
                              • Furkan CevikF Furkan Cevik referenced this topic on
                              With your input, this post could be even better πŸ’—
