    2. Vinicius Gimenez Figuerola
    Vinicius Gimenez FiguerolaV Offline
    • Posts 5
    @Vinicius Gimenez Figuerola
    Vinicius Gimenez Figuerola Unfollow Follow
    • RE: [BUG] I`m adding new commands and it`s executes the command but Alexas threats as a doorbell
      @Russ oohh the option to disable the doorbell press notification for me just appeared without I've done nothing and yes it works if I disable this Alexa won't notify anymore, very good 😁
      @Russ Yes, a permanent solution needs to be found. What I did is just a workaround because I was getting tired of Alexa saying "Someone is in front of..." every time I asked her to run a command.
      @Russ Oh, yes. For now, that's exactly what I've done. I've created a routine for each command that enables the do not disturb for about 5 seconds before running the command.
      This started Happening after I ve tested that field Voice/MCP Reply in the command, I use the Alexa skill for Smart Home, even I`ve deleting that field it doesn t stop threating everything as a doorbell
    • [BUG] I`m adding new commands and it`s executes the command but Alexas threats as a doorbell
      New Smart Home commands are discovered by Alexa correctly and execute normally, but Alexa says "Ding Dong.... Someone is in front of <device name>" for every newly created command. Older commands created weeks ago still behave correctly.
