@Russ Thank you.
So this what i have. A mini PC running detection for my darts setup. Then another mini PC running the funky stuff for the darts setup and a secondary monitor. The only reason i am doing this is because i cannot solder a second external power button onto the second pc. And it will be hidden so not easy to access. And the detection pc is running on Ubuntu. Dont know how much of an issue that will be if i wanted to use it too start the second pc.
And all on WIFI
R
Offline
RE: Turn PC on/off
Turn PC on/off
Hi
I have tried with gemini to get a solution but they could only help with the turn off. I would like to be able to turn my windows pc on/off using my google assistant please? I am not familiar with coding and writing scripts or even triggercmd. Any help would be greatly appreciated. Thanks
