    2. Roberto Luis
    • Posts 8
    Posts made by Roberto Luis
    • "Monitors Off" Don't work
      Neither commands are working for me.
      I use the monitor "Acer GN246HL" on the dvi port
      Roberto LuisR
      Roberto Luis
    • RE: How to join an especific discord channel
      @Russ Thx for the help
      Roberto LuisR
      Roberto Luis
      @roberto-luis It worked!
      IDK what changed, but with this name the triggercmd could start my script.
      #SingleInstance Force
      CoordMode, Pixel, Screen
      CoordMode, Mouse, Screen
      Loop
          PixelSearch, x, y, 1925, 11, 1994, 201, 0x7EDB32,, Fast
          if (ErrorLevel = 0)
              MouseMove, %x%, %y%
              break
      Click, Left
      Loop 10
      	Send, {Tab}
      	Sleep, 300
      Loop 8
          Send, {Down}
          Sleep, 300
      Send, {Enter}
      Here u are the code, just need to change the pixel that u wanna search to click first (Pixel of the discord server's icon)
      Roberto LuisR
      Roberto Luis
      Not at all, it continues just "ToTalk.exe.ahk"
      Roberto LuisR
      Roberto Luis
      It returns me this message when I try to turn my .ahk archive onto .exe
      It says successfully compiled, but no new archive is created. Then I tried to put the content of the message on the triggercmd's command, but nothing is happening
      Roberto LuisR
      Roberto Luis
      @russ In fact i'm having some problems to run the script .ahk with the triggercmd, when i do it manually, it works very well, but when I copy and paste the script's target and ask triggercmd to do it, it doesn't work.
      Could u help me with it?
      Then I can share the entire project working here
      Roberto LuisR
      Roberto Luis
      @roberto-luis I Did it! I made a script using Autohotkey that can find the server and click on it searching for the correct color. Then, the script clicks on it and does the keyboards' commands to join the correct channel
      Roberto LuisR
      Roberto Luis
    • How to join an especific discord channel
      I was trying to find a way to do this and didn't find an especific solution for it, but I saw a script that could execute some keyboards commands. In fact, u can navigate on discord using just your keyboard, I mapped a bunch of commands that could help me join an especific channel but IDK how to transfer it to a script.
      // I know that it's kinda amateur but thats the way that I found it lmao
      Tab //start the navigation on discord using the keyboard
      down arrow x10 times //going down to find the correct server to join (particular value)
      press enter //to open the server
      press tab x9 times //to start navigating on the channels
      down arrow x9 times //to select the correct voice channel
      press enter //to join it
      I wonder If someone could transfer it to an VBSscript and help me to use it on TriggerCMD
      Roberto LuisR
      Roberto Luis
