    2. Richard Rico
    Richard Rico
    @Richard Rico
    Richard Rico Unfollow Follow
    Latest posts made by Richard Rico
    • RE: new commands aren't showing up on
      @Russ said in new commands aren't showing up on:
      systemctl status triggercmdagent
      its working now!!! I think what happened was that I originally installed this as root. To fix I did this:
      I uninstalled the background service using the tray icon & simply reinstalled it using the icon. This is my out put now:
      Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; preset: enabled)
      Active: active (running) since Mon 2024-09-30 23:07:55 EDT; 40s ago
      Main PID: 2344132 (node)
      Tasks: 15 (limit: 18707)
      Memory: 73.8M (peak: 90.6M)
      CPU: 420ms
      └─2344132 node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /home/rrico/.TRIGGERcmdData
      Sep 30 23:07:55 localhoe env[2344132]: Write backup completed.
      Sep 30 23:07:55 localhoe env[2344132]: |> Now connected to https://www.triggercmd.com.
      Sep 30 23:07:55 localhoe env[2344132]: ___/ For help, see: http://bit.ly/2q0QDpf
      Sep 30 23:07:55 localhoe env[2344132]: (using sails.io.js node SDK @v1.2.1)
      Sep 30 23:07:55 localhoe env[2344132]: Connected at: Mon Sep 30 2024 23:07:55 GMT-0400 (Eastern Daylight Time)
      Sep 30 23:07:55 localhoe env[2344132]: Initiated command removals
      Sep 30 23:07:55 localhoe env[2344132]: Initiated command adds
      Sep 30 23:07:55 localhoe env[2344132]: { message: 'Subscribed to 66fa0390a3b76800139976ac!' }
      Sep 30 23:07:55 localhoe env[2344132]: Added update-nonprod
      Richard RicoR
      Richard Rico
      systemctl status triggercmdagent output is below:
      rrico@localhoe:~/Downloads/keys-0930/test$ systemctl status triggercmdagent
      × triggercmdagent.service - TRIGGERcmd Agent
      Active: failed (Result: start-limit-hit) since Mon 2024-09-30 01:14:16 EDT; 21h ago
      Duration: 154ms
      Process: 1866618 ExecStart=/usr/bin/env node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
      Main PID: 1866618 (code=exited, status=0/SUCCESS)
      CPU: 196ms
      Sep 30 01:14:16 localhoe systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
      Sep 30 01:14:16 localhoe systemd[1]: triggercmdagent.service: Start request repeated too quickly.
      Sep 30 01:14:16 localhoe systemd[1]: triggercmdagent.service: Failed with result 'start-limit-hit'.
      Sep 30 01:14:16 localhoe systemd[1]: Failed to start triggercmdagent.service - TRIGGERcmd Agent.
      Richard RicoR
      Richard Rico
      I ran the install script to get the service installed, got this when I tried to restart it:
      • list itemtriggercmdagent.service: Start request repeated too quickly
      • triggercmdagent.service: Failed with result 'start-limit-hit'
      • Failed to start triggercmdagent.service - TRIGGERcmd Agent.
      Richard RicoR
      Richard Rico
    • new commands aren't showing up on
      hello, I've tried using both the gui & text editor. new commands are not showing up when I use the app or the web app to view triggers. only 1 shows up. Im running ubuntu 24.x lts
      Richard RicoR
      Richard Rico
