    2. Red Sufi
    • Posts 7
    • Best 1
    Red Sufi
    @Red Sufi
    Red Sufi Unfollow Follow
    Best posts made by Red Sufi
    • RE: Tasker and parameters
      @Russ thanks for the quick reply. I tried it out and it worked perfectly. Thanks again
      Red SufiR
      Red Sufi
    Latest posts made by Red Sufi
    • RE: Tasker text to be read by Alexa
      ive finally got this to work with your help
      i didnt know how to implement tasker_write_text.bat but used a combination of autoremote,tasker and eventghost to create the text file
      many thanks for your help and patience
      Red SufiR
      Red Sufi
      @Russ thanks
      funny thing is i did try that
      i tried remove params and made no difference and i tried using TRIGGERcmd, TC, and Trigger Command Alexa skill, and none of them worked
      Red SufiR
      Red Sufi
      @Russ thanks again
      im making progess but still having problems with Alexa saying the replies
      i think im having the same issues reported here
      https://www.triggercmd.com/forum/topic/1013/alexa-not-saying-voice-reply/4
      you can see in the screenshot below that my command did successfully run with the result but its not read by alexa
      i had both the original skill https://www.amazon.co.uk/gp/product/B06XFN2TZN
      and the smart home skill linked
      i tried just using the original skill and it would still run but again Alexa would not read it
      any ideas?
      Red SufiR
      Red Sufi
      @Russ thanks im having a look at these
      i tried running the When did i last reboot command from examples and nothing happened. Is that because i do not have tcmd command line tool installed?
      does the script just need my profile name replaced such as follows
      redsufi.TRIGGERcmdData\SendResult.bat Your Text
      do i need to replace the bit Your Text with a variable name from part 1 ?
      sorry for the noob questions
      thanks
      Red SufiR
      Red Sufi
    • Tasker text to be read by Alexa
      Hi all
      is there a way to send a text via tasker to be read aloud by alexa
      i have seen examples of using parameters which can be read by alexa but cant figure it out
      thanks
      Red SufiR
      Red Sufi
      Red SufiR
      Red Sufi
    • Tasker and parameters
      hi there im a complete newbie and have searched for the answer but couldnt find it
      im trying to use tasker to send a http request with a parameter to triggercmd
      for example to open a youtube video i would create a bat file such as follows
      start https://www.google.com/search?q=%1
      im stuck on how to put the parameter in the tasker http request task
      i have tried after the token line but it doesnt work
      any help would be much appreciated
      thanks
      Red SufiR
      Red Sufi
