    2. Pé de Pano
    • Best 1
    Posts made by Pé de Pano
    • RE: i can't add trigger on my raspberry pi
      It all worked out! Thank you very much Russ, you helped me a lot.@russ
      Pé de PanoP
      Pé de Pano
      @russ said in i can't add trigger on my raspberry pi:
      hello, I received the following output
           Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vend>
           Active: active (running) since Fri 2022-05-06 00:28:26 BST; 1 day 12h ago
         Main PID: 404 (node)
            Tasks: 11 (limit: 1598)
              CPU: 3.577s
                   └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /roo>
      May 07 13:09:12 raspberrypi env[404]: _-|>_-  (attempt #3)
      May 07 13:09:12 raspberrypi env[404]:   |>    Socket reconnected successfully a>
      May 07 13:09:12 raspberrypi env[404]: \___/   being offline at least 132038.91 >
      May 07 13:09:12 raspberrypi env[404]:   |>    Now connected to https://www.trig>
      May 07 13:09:12 raspberrypi env[404]: \___/   For help, see: http://bit.ly/2q0Q>
      May 07 13:09:12 raspberrypi env[404]:         (using sails.io.js node SDK @v1.1>
      May 07 13:09:12 raspberrypi env[404]:          Connected at: Sat May 07 2022 13>
      May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' }
      lines 1-19/19 (END)...skipping...
              CPU: 3.577s
                   └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      May 07 13:09:12 raspberrypi env[404]:   |>    Socket reconnected successfully after
      May 07 13:09:12 raspberrypi env[404]: \___/   being offline at least 132038.91 seconds.
      May 07 13:09:12 raspberrypi env[404]:   |>    Now connected to https://www.triggercmd.com.
      May 07 13:09:12 raspberrypi env[404]: \___/   For help, see: http://bit.ly/2q0QDpf
      May 07 13:09:12 raspberrypi env[404]:         (using sails.io.js node SDK @v1.1.13)
      May 07 13:09:12 raspberrypi env[404]:          Connected at: Sat May 07 2022 13:09:12 GMT+0100 (British Summer Time)
      Pé de PanoP
      Pé de Pano
      @russ hello russ, I edited the commands.json to:
      {"trigger":"python test","command":"python /root/led.py","ground":"background","voice":""}
      but when saving I can't see the trigger on the site, only Gnome Editor. Could you help me?
      Pé de PanoP
      Pé de Pano
    • i can't add trigger on my raspberry pi
      Hello Russ, I managed to install the Trigger cmd on my Raspberry pi, insclusive managed to see it on the site. But I'm having trouble adding a Trigger. I could not edit the file: commands.json. I opened the terminal as root user, and typed the following code: /root/. TRIGGERcmdData/commands.json, and I received the output: Permission denied. I'd like you to help me. Thank you right now.
      Pé de PanoP
      Pé de Pano
