Okay, the command lines you provided work, and I also changed my command word to just "shut" so Alexa can recognize it better. Overall, thanks a lot for helping me, TriggerCMD is definitely a great tool for the raspberry pi.
RE: Can't add command with raspberry pi 3b+
Unlinking the Trigger CMD with Alexa doesn't seem to help.
My conversation with Alexa is like this:
Me: Alexa, open Trigger CMD
Alexa: Say something like: open calculator on ...
Me: Shutdown Magic Mirror (Magic Mirror is the name of the device)
Alexa: Beeped... and nothing happen. -
Okay, I was editing the wrong file all along. Now I do see my trigger online, and I can activate it. However, I still can't tell Alexa to execute the new command. Once again, Alexa just beeped and then nothing happened. So right now this is what I have under /root/.TRIGGERcmdData/commands.json.
{"trigger":"shutdown","command":"shutdown now","ground":"background","voice":"shutdown","allowParams": "false"}
Below is the full commands.json file; it is under /home/pi/.TRIGGERcmdData.
]Even when I changed the original reboot command to shutdown. The system still reboots.
{"trigger":"Reboot","command":"shutdown -P now","ground":"background","voice":"reboot","allowParams": "false"},
Re: Raspberry Pi setup
I have tried opening the commands.json file and add
inside the parameters. However, the command does not show up on the website; and when I tried to execute the shutdown command through Alexa, it just beeped and did nothing. Can somebody help me with this problem?
P.S: It does work with the original commands.
