    2. Moacir Vilela Sêga
    • Following 1
    • Posts 6
    • Best 3
    Moacir Vilela Sêga
    @Moacir Vilela Sêga
    Moacir Vilela Sêga Unfollow Follow
    Best posts made by Moacir Vilela Sêga
    • RE: Unable to log into dashboard
      @barry-hamilton Same problem here
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
    • RE: Javascript error occurred in the main process
      Got the same problem as you. Something broke
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
      @Russ I suppose you are already working on it?
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
    Latest posts made by Moacir Vilela Sêga
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
    • RE: Pass color and brightness parameters using TRIGGERcmd Smart Home Alexa skill
      @russ I dont know what to tell you now. It is just working normally now. I didn't change neither my script nor tried to re-add the device.
      I decided to test it before changing to your script and it worked.
      posted in Announcements
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
      @russ I am using Alexa. I did a simple python script
      import pyttsx3
      import threading
      import sys
      from pycaw.pycaw import AudioUtilities, IAudioEndpointVolume, IAudioEndpointVolumeCallback
      from comtypes import CLSCTX_ALL, COMObject
      from ctypes import POINTER, cast
      class fala:
          def __init__(self,msg,voice=0):
              threading.Thread(target=self.thread,args=(msg,voice,)).start()
          def thread(self,msg,voice):
              tts = _TTS(voice)
              tts.start(msg)
              del(tts)
      class _TTS:
          engine = None
          rate = None
          def __init__(self,voice):
              self.engine = pyttsx3.init()
              self.engine.setProperty('volume',1.0)
              voices = self.engine.getProperty('voices')
              self.engine.setProperty('voice', voices[voice].id)
          def start(self,text_):
              self.engine.say(text_)
              try:
                  self.engine.runAndWait()
              except:
                  fala(text_)
      class AudioEndpointVolumeCallback(COMObject):
          _com_interfaces_ = [IAudioEndpointVolumeCallback]
          def OnNotify(self, pNotify):
              print('OnNotify callback')
      list2 = sys.argv[1:]
      devices = AudioUtilities.GetSpeakers()
      interface = devices.Activate(IAudioEndpointVolume._iid_, CLSCTX_ALL, None)
      volume = cast(interface, POINTER(IAudioEndpointVolume))
      callback = AudioEndpointVolumeCallback()
      volume.RegisterControlChangeNotify(callback)
      try:
          if isinstance(int(sys.argv[1]),int):
              fala('volume definido para ' + str(int(sys.argv[1])))
              volume.SetMasterVolumeLevelScalar(int(sys.argv[1])/100,None)
      except:
          fala(' '.join(list2))
      So if I say a number it changes the volume, but if I say a color or "Turn on/off" it says On, Off or the Color. (Basically it tries to say it out loud if the parameter is not a number)
      Now, it only works during On and Off. All the colors or the numbers are not working as valid parameters.
      This is how it is coded in TriggerCMD currently:
        "trigger": "Protocolo",
        "command": "python \"D:\\Programming\\Python\\teste vozes.py\"",
        "offCommand": "",
        "ground": "foreground",
        "voice": "Protocolo",
        "voiceReply": "",
        "allowParams": "true"
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
      Did it stop working? I used this to control my computer volume, and I think since yesterday it isnt working anymore, even after deleting the devices
      Moacir Vilela SêgaM
      Moacir Vilela Sêga
