will do thanks
computer change out
Had everything working perfectly several months ago. My computer went south. New computer now and not sure what my issue is. Things work from the TCMD website and the local agent/editor. Just no luck when using my google home. Reinstalled token with new token but still no luck. Can you point me in the right direction?
RE: Multiple Accounts on Google Home
@russ
I must have something wrong. Ill check again.
thanks -
I guess this is the same issue I'm dealing with. Not sure why google home can recognize different voices but won't run each others triggercmd. Thought I could just use my URL for a command call with IFTTT but that didn't work. Her google account, her IFTTT acount with my TCMD bookmarked URL but still no go! Just trying to find a work arround
RE: command ques
@russ
I edited out the "lamp" to use only "Floor" and i did get the audio response from Cortana that was correct but the actual command did not run. I triggered it from TCMD website and it ran.??? Don't know if that helps. -
RE: command ques
@russ
Hey Russ I was never able to figure out what was keeping the agent from installing. I was using Avast. I killed most of the services that might have caused it. I ended up dumping the OS and moving to win 10 from 7 just to get current. What I am really working on is getting my wife set up to control my x10 devices by voice. It's the problem of two accounts as you have discussed before. My answer was to just set up another computer and try Cortana. I have created a seprate TCMD for her and both are working but just not Cortana doesn't communicate with her Agent. The TCMD's work in Agent and on Web triggers so I'm not sure where to look from here. -
RE: command ques
@russ
Hey Russ I’m assuming I can only have one agent per computer or does tcmd call the corrrect agent based on the voice from google home recognition -
command ques
I have several working x10 devices tha all work with batch file/agent/web TCMD and voice (on Google Home) with one exception. Floor Lamp OFF will not work with google home. Reports "could not find a command with run Floor Lamp OFF on ..... It's obviously there and works when I say "tell triggercmd to run Floor Lamp off. I use the ifttt with all of these with no issues. I just reset the URL in ifttt /web hook from triggercmd bookmarks. Any ideas?
dual commands
Re: Welcome to the TRIGGERcmd forum!
I'd like to use two commands on the same command line in the Agent. I'm working with x10 commands in a batch file on win7. Any ideas?
RE: no computer call
@russ Thanks for a great program. Let me know if you come up with a solution.
