@Russ I reinstalled it on my Windows and disabled and activate the skill back in and it's working. If it stop, I'll be back here to inform you, thank you.
Posts made by Lucas Ribeiro
RE: TriggerCMD skill working, but not directlyposted in General Discussion
I'm also in trouble with alexa, if i use the routine with the command she doesn't say anything and the command doesn't execute, if i try to execute the direct command "turn on suspend" by alexa, she says "sorry it seems there are some error, to control the suspend, try to disable and activate the skill " , I use the TRIGGERcmd Smart Home skill and it worked well, in the last days the problem started, I'm from Brazil
