@Russ thx, dude!!
WhatsApp Microsoft Store Alexa
Does anyone know a command for the new WhatsApp from the Microsoft Store? I used Alexa a lot to call the old WhatsApp, but now it is mandatory to have the one from the Microsoft Store installed
RE: Error
@lexar-s the USB error suggest a driver issue.
Windows installs what it thinks is the best driver for devices and these are not always the ones that work.
What USB devices do you have plugged into your PC?
Perhaps if you posted your full python script it would help @russ or others figure out what else may be a issue.Ok'
from selenium import webdriver from selenium.webdriver.common.keys import Keys from selenium.webdriver.common.by import By from selenium.webdriver.support.ui import WebDriverWait from selenium.webdriver.support import expected_conditions as EC import time import sys if len(sys.argv) == 2: movie = sys.argv[1] else: movie = ' '.join(sys.argv[1:]) PATH = r"C:\Users\Lexar's\Documents\ChromeDriver\ChromeDriver.exe" driver = webdriver.Chrome(PATH) driver.get("https://www.netflix.com/br/login") element = driver.find_element_by_name("userLoginId") element.send_keys("netflix@gmail.com") time.sleep(0.2) element2 = driver.find_element_by_name("password") element2.send_keys("netflix") time.sleep(0.3) element2.send_keys(Keys.RETURN) time.sleep(2) profile = driver.find_element_by_link_text("TELA02") profile.click() time.sleep(3) search = driver.find_element_by_class_name("searchBox") search.click() time.sleep(1) searchbox = driver.find_element_by_name("searchInput") searchbox.send_keys(movie) time.sleep(0.5) searchbox.send_keys(Keys.RETURN) time.sleep(2) scene = driver.find_element_by_xpath("/html/body/div[1]/div/div/div[1]/div/div[2]/div/div/div/div[2]/div/div/div[1]/div/div/div/div/div/div[1]") scene.click() time.sleep(0.5) submit = driver.find_element_by_xpath("//button[@class='color-primary hasLabel hasIcon ltr-1jnopvq']") submit.click() time.sleep(5) move = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerBack tooltip-button tooltip-button-pos-center tooltip-button-align-right']") move.send_keys(Keys.TAB) time.sleep(0.5) fullscreen = driver.find_element_by_xpath("//button[@class='touchable PlayerControls--control-element nfp-button-control default-control-button button-nfplayerFullscreen']") fullscreen.click()Another detail, she doesn't search for the movie or series through the script I made
RE: Error
@lexar-s, how are you getting that error? Are you using selenium?
Google translated that as, "The I/O operation was aborted due to a thread exit or an application request. (0x3E3)"
@Russ Yes, I am but when I put the PATH path "C:\Users\Lexar's\Documents\ChromeDriver\ChromeDriver.exe" it doesn't work and when I leave it (PATH) driver = webdriver.Chrome(PATH) it works, but with USB error The I/O operation was aborted due to a thread exit or an application request. (0x3E3
[7688:10380:0128/113046.882:ERROR:chrome_browser_main_extra_parts_metrics.cc(227)] START: ReportBluetoothAvailability(). If you don't see the END: message, this is crbug.com/1216328.
[7688:10380:0128/113046.882:ERROR:chrome_browser_main_extra_parts_metrics.cc(230)] END: ReportBluetoothAvailability()
[7688:10380:0128/113046.885:ERROR:chrome_browser_main_extra_parts_metrics.cc(235)] START: GetDefaultBrowser(). If you don't see the END: message, this is crbug.com/1216328.
[7688:5364:0128/113046.886:ERROR:device_event_log_impl.cc(214)] [11:30:46.886] USB: usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: Um dispositivo conectado ao sistema nÒo estß funcionando. (0x1F)
[7688:5364:0128/113046.887:ERROR:device_event_log_impl.cc(214)] [11:30:46.887] USB: usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: Um dispositivo conectado ao sistema nÒo estß funcionando. (0x1F)
[7688:10380:0128/113046.895:ERROR:chrome_browser_main_extra_parts_metrics.cc(239)] END: GetDefaultBrowser()What is wrong with my python script?
Error
Re: Open Specific Netflix Movie with Alexa
@Russ can you help me error? usb_device_handle_win.cc:1050 Failed to read descriptor from node connection: A opera o de E/S foi anulada devido a uma sa da de thread ou a uma requisi o de aplicativo. (0x3E3)
