    2. Igor Gallette
    Igor GalletteI Offline
    • RE: Installation has failed
      @russ
      I have already disabled the firewall but the error persists.
      But after updating windows, the "open setup log" is showing the error I sent in the previous message.
      Igor GalletteI
      Igor Gallette
      @tuicemen
      It is on 10.0.19043.
      However I did an update and now it shows this error below:
      2022-03-18 12:32:54> Program: Starting Squirrel Updater: --install .
      2022-03-18 12:32:54> Program: Starting install, writing to C:\Users\User\AppData\Local\SquirrelTemp
      2022-03-18 12:32:54> Program: About to install to: C:\Users\User\AppData\Local\TRIGGERcmdAgent
      2022-03-18 12:32:54> Program: Install path C:\Users\User\AppData\Local\TRIGGERcmdAgent already exists, burning it to the ground
      2022-03-18 12:32:55> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
         em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
         em System.IO.File.InternalDelete(String path, Boolean checkHost)
         em System.IO.File.Delete(String path)
         em Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file)
         em Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1()
         em System.Threading.Tasks.Task.InnerInvoke()
         em System.Threading.Tasks.Task.Execute()
      --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada ---
         em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
         em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
         em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext()
         em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext()
         em Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext()
         em Squirrel.Utility.<LogIfThrows>d__42.MoveNext()
      2022-03-18 12:32:55> Unhandled exception: System.AggregateException: Um ou mais erros. ---> System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
         em System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
         em Squirrel.Update.Program.<Install>d__4.MoveNext()
         --- Fim do rastreamento de pilha de exceções internas ---
         em System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
         em System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
         em System.Threading.Tasks.Task.Wait()
         em Squirrel.Update.Program.executeCommandLine(String[] args)
         em Squirrel.Update.Program.main(String[] args)
      ---> (Exceção Interna N° 0) System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
         em Squirrel.Update.Program.<Install>d__4.MoveNext()<---
      I have already accessed the page below and deleted all the files but the error remains.
      C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg```
      I've also tried restarting the computer and it didn't work.
      Igor GalletteI
      Igor Gallette
      @tuicemen
      Yes, I tried but the error remains
      Igor GalletteI
      Igor Gallette
    • Installation has failed
      Hi!
      Does anyone know how to resolve the error below?
      Check other topics, however the solutions were for 32bit windows.
      The windows I use is 10, 64bit.
      Thank you very much
      Igor GalletteI
      Igor Gallette
