@Russ Thanks for the quick fix! I have tested it, now it works
Latest posts made by Emanuel Werner
RE: Bug with IFTTTposted in General Discussion
I have a problem with IFTTT:
I have created two applets there. Applet1 and Applet2. Both applets have a TriggerCMD trigger (Trigger1 and Tigger2).
On their own, both applets work in principle. As soon as the TiggerCMD trigger is called (in my case via the shortcut link), the specified action is executed via IFTTT.
The problem is that when I trigger Applet1, Applet2 is also triggered about half an hour later. The activity overview of applet 2 in IFTTT then also correctly states that Trigger1 was triggered at X o'clock.
The half-hour delay is not always identical. I have already deleted the Applet and the trigger completely and created them again. Nevertheless, Applet2 is also triggered by Applet1.The same problem exists the other way round: Applet1 is also executed by Trigger2 about half an hour later.
What is the problem here?
