    2. Eduardo Lezcano
    Eduardo LezcanoE Offline
    • Posts 6
    Eduardo Lezcano
    @Eduardo Lezcano
    Eduardo Lezcano Unfollow Follow
    • RE: Alexa always response "this command is not compatible with this"
      Hi Russ,
      Thanks for your help again. I have followed all your steps and when I have launched the trigger a new firefox window was opened in my raspberry, so it's work.
      But, the voice commands still do not appear on the website. What are the next steps from here?
      BR,
      Eduardo
      Eduardo LezcanoE
      Eduardo Lezcano
      @Russ said in Alexa always response "this command is not compatible with this":
      The service on the raspberry pi is the background service so it only runs background commands as the root user.
      I have tried always to configure the commands as foreground because I can't see the background commands, even if I execute the installdaemon.sh file.
      So I can't use the background command in my pi.
      I have tried to run triggercmdagent as root or pi, and configure one computer by each one (not at the same time because I'm not subscribed as you comment) but it didn't work.
      I don't know what is the problem.
      Thanks
      Eduardo LezcanoE
      Eduardo Lezcano
      About the command through the web interface, when I trigger the command with the button, the order is sent to my raspberry and I can see it in the service, but nothing happens.
      Thanks
      BR
      Eduardo LezcanoE
      Eduardo Lezcano
      I have checked with the default command.json configuration, the voice word in the default file for the foreground is "edit":
      {"trigger":"Gnome Editor","command":"gedit","ground":"foreground","voice":"edit","allowParams": "false"}
      But if I say " Alexa, abre edit" it still saying "edit is not compatible with this"
      I have sent you my email by chat. Thanks
      Eduardo LezcanoE
      Eduardo Lezcano
      I said to Alexa "Alexa open Television" for example, television is one of the commands that have to open a browser.
      I have installed the second one, TRIGGERcmd Smart Home skill, because I can't find another one in Spain.
      I can't see the voice sentences in the web interface.
      Thanks for your response
      Eduardo LezcanoE
      Eduardo Lezcano
    • Alexa always response "this command is not compatible with this"
      I have configured Alexa and Triggercmd in my raspberry pi 3, I have added some commands in the command.json configuration.
      Triggercmd skill detects it correctly, but when I as Alexa to execute them, it always response "[name of the command] is not compatible with this", do you know what can be the problem? Thanks
      Eduardo LezcanoE
      Eduardo Lezcano
