    2. Daniel Millan
    • Posts 8
    • Best 1
    Posts made by Daniel Millan
    • RE: Parameters with Alexa not working
      I'm talking about when I ask Alexa to open the skill without giving a command and say the pattern later.
      1. I say "Alexa, abra Execute Comando"
      2. Alexa replies "Diga algo como execute a calculadora no Office PC" (It could be replaced by say "Qual é seu comando?" and wait for my command)
      3. I say "{Trigger} with parameter {Params}"
      Daniel MillanD
      Daniel Millan
      Hi, @Russ
      "{Trigger} com parâmetro {Params}" only works if I call the skill before.
      The pattern for triggering instantly (without invoking the skill) is still confusing and very long.
      Another solution would be not to provide instructions ("Diga algo como [...]") every time I call the skill.
      Daniel MillanD
      Daniel Millan
      Is the first one already working or is it being implemented? (I tried to use, but it didn't work)
      Thanks for your help!
      Daniel MillanD
      Daniel Millan
      The trigger works, but the command is too long and doesn't make sense in Portuguese.
      "Execute Comando X com parâmetro Y" would be a better pattern to use than "pergunte Execute Comando para executar X com o parâmetro Y".
      Daniel MillanD
      Daniel Millan
    • Parameters with Alexa not working
      I can't pass parameters with Alexa (in Portuguese) using the Skill "TRIGGERcmd Smart Home".
      If I use the Skill "Execute comando", I have to talk more and every time I give a command the skill gives the same long instructions, wasting time.
      There is a way to resolve this issue? Can you make "Execute comando" better to use or allow parameters with "TRIGGERcmd Smart Home"?
      Daniel MillanD
      Daniel Millan
    • RE: Press the Down Arrow key (or any other key)
      Okay, thanks.
      Daniel MillanD
      Daniel Millan
      @Russ I want to run it before I am logged into the computer.
      Daniel MillanD
      Daniel Millan
      Can I run this in a background command?
      Daniel MillanD
      Daniel Millan
