    2. Craig OK
    Craig OKC Offline
    • RE: Avoid saying 'with parameter' when passing arguments via Alexa?
      @Russ I appreciate you putting some thought into it. I might take a look at IFTTT then see if there is anything else I can do
      posted in Alexa
      Craig OKC
      Craig OK
    • RE: Arch Linux install
      @Tiago-Mártires Pretty much the same thing but I added this line to crontab:
      @reboot node /usr/share/triggercmdagent/resources/app/src/agent.js &
      posted in Linux
      Craig OKC
      Craig OK
    • Avoid saying 'with parameter' when passing arguments via Alexa?
      Unsure if there is an easy way to do this. I wrote a program to search and download torrents using qbittorrent based on a given search string.
      The end goal being something like: "Alexa, download Ubuntu server"
      TriggerCMD is awesome, but "Alexa, launch download torrent with parameter Ubuntu server" isn't really as simple.
      New to this but would love to make use of it more!
      I did look at adding a routine but didn't see how I could combine that with the parameters
      posted in Alexa
      Craig OKC
      Craig OK
