@Russ Hi Russ! I have created new commands for testing purposes but only the ones that are marked as "foreground" were showing up on the website... So I used the option "remove background services" and then "install background services" and right after that the background commands appeared on website.... Not sure what happened, maybe something was stuck and cleared by itself after the reinstall...anyway, it's working properly now!! Thank you for all quick support, really appreciate that!
Best regards
RE: How do you load Triggercmd on boot on Ubuntu?
@Russ Hi, first I would like to thank you for all support!
I'm trying to load Triggercmd right after boot on Linux Mint 21.3 Cinnamon.
Here is my current setup:
Triggercmd is already working with Alexa with only one trigger configured ( to shutdown my machine) but for it to work, then I first need to put my PC credentials and wait for desktop to load, then command works...I was wondering if it is possible to load Triggercmd right after boot so I don't have to login on linux mint for commands to work...
FYI - I have triggercmdagent.service active (running) and already installed Background service (via Install background service option) on linux mint tray
thanks!!
