    2. Andy Kutruff
    Posts made by Andy Kutruff
    • Raspbery Pi docker / docker-compose
      Hey there. I'm trying to get triggercmd setup and running on a raspberry pi in headless mode inside a docker container. There aren't any arm64 builds on dockerhub, so I gave it a whirl myself. In general I need everything running in docker these days, so any help would be appreciated.
      The environment variables don't appear to be respected, and it seems like there's a daemon install missing? I tried also using the raspberry pi deb directly but that was just getting weird.
      TOKEN environment variable not found.  We'll prompt for a token.
      COMPUTERID environment variable not found.  We'll create a new computer in the account.
      COMMANDS environment variable not found.  We'll use the default commands.
      Daemon install: false
      No token exists.  Login to request one.
      Docker files below
      ENV DEBIAN_FRONTEND=noninteractive
      RUN apt-get -y update \
          && apt-get -y upgrade \
          && apt install -y nodejs npm wget
      RUN wget https://raw.githubusercontent.com/rvmey/TRIGGERcmd-Agent/master/ubuntupackage.json -O package.json
      RUN npm install
      RUN wget https://raw.githubusercontent.com/rvmey/TRIGGERcmd-Agent/master/src/agent.js
      RUN wget https://raw.githubusercontent.com/rvmey/TRIGGERcmd-Agent/master/src/gd_bundle-g2-g1.crt
      RUN wget https://raw.githubusercontent.com/rvmey/TRIGGERcmd-Agent/master/src/sendresult.sh
      RUN wget https://raw.githubusercontent.com/rvmey/TRIGGERcmd-Agent/master/src/linuxcommands.json
      COPY start.sh start.sh
      CMD ./start.sh
      docker-compose.yml
      version: "3"
      services:
        triggercmd:
          build: .
          image: triggercmd
          environment:
            - TOKEN=<redacted>
            - COMPUTERID=mycomputer
            - TZ=America/New_York
          volumes:
            - data:/root/.TRIGGERcmdData
          restart: always
      volumes:
        data: {}
      Andy KutruffA
      Andy Kutruff
