    2. al.mastro
    A
    Posts made by al.mastro
    • RE: HTTP Request Not Firing
      @Russ said in HTTP Request Not Firing:
      calc & "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" "http://192.168.0.229:3480/data_request?id=action&output_format=json&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=2"
      Works perfect, I am very happy with the result!
      Thank you.
      A
      al.mastro
      "trigger": "scene test ",
      "command": "calc' & Start http://192.168.0.229:3480/data_request?id=action&output_format=json&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=2",
      "ground": "foreground",
      "voice": "scene one",
      "voiceReply": "",
      "allowParams": "true"
      It runs calc fine and opens up chrome and inputs only a section of the URL (http://192.168.0.229:3480/data_request?)
      Eventually, I want this to run a "shutdown" scene. (replace calc with shutdown in 1 min" ).
      I am not using curl, wanted to try to avoid using that protocol for simplicity
      It might help to mention that this is only going to be triggered within a Local network.
      A
      al.mastro
    • HTTP Request Not Firing
      Hi all
      I am trying to trigger a HTTP request for a lighting control system (vera) to trigger a scene via a URL to an IP address + run a CMD command. When I run the trigger it doesn't input the full URL that entered. Does anyone know why? am I missing something?
      Any help would be great
      Thank you
      A
      al.mastro
