    HTTP Request Not Firing
    6 Posts 2 Posters 1.0k Views 1 Watching
    • A Offline
      al.mastro
      Hi all
      I am trying to trigger a HTTP request for a lighting control system (vera) to trigger a scene via a URL to an IP address + run a CMD command. When I run the trigger it doesn't input the full URL that entered. Does anyone know why? am I missing something?
      Any help would be great
      Thank you
        Russ @al.mastro
        @al-mastro, can I see your full command text or the batch file you're using? Also, are you using curl?
        • A Offline
          al.mastro
          "trigger": "scene test ",
          "command": "calc' & Start http://192.168.0.229:3480/data_request?id=action&output_format=json&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=2",
          "ground": "foreground",
          "voice": "scene one",
          "voiceReply": "",
          "allowParams": "true"
          It runs calc fine and opens up chrome and inputs only a section of the URL (http://192.168.0.229:3480/data_request?)
          Eventually, I want this to run a "shutdown" scene. (replace calc with shutdown in 1 min" ).
          I am not using curl, wanted to try to avoid using that protocol for simplicity
          It might help to mention that this is only going to be triggered within a Local network.
            Russ @al.mastro
            @al-mastro, please try this:
            calc & "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" "http://192.168.0.229:3480/data_request?id=action&output_format=json&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=2"
            For me it opened calculator and a Chrome tab with that full URL in it.
            • A Offline
              al.mastro
              @Russ said in HTTP Request Not Firing:
              Works perfect, I am very happy with the result!
              Thank you.
                Russ @al.mastro
                @al-mastro, awesome. You're welcome. I'm glad that worked.
