    Trigger a command from Unity
    Instructions
    1.0k
      This is an example script you can put on any object in Unity, so now you can trigger commands in the games you build.
      using System.Collections;
      using System.Collections.Generic;
      using UnityEngine;
      using UnityEngine.Networking;
      public class scr : MonoBehaviour
          // Start is called before the first frame update
          void Start()
          // Update is called once per frame
          void Update()
              if (Input.anyKeyDown)
                  Debug.Log("A key or mouse click has been detected");
                  var trigger = "calculator";
                  var computer = "laptop";
                  var parameters = "";
                  var token = "(your token)";
                  StartCoroutine(TriggerCMD(trigger, computer, parameters, token));
          IEnumerator TriggerCMD(string trigger,string computer,string parameters, string token)
              UnityWebRequest www = UnityWebRequest.Get("https://www.triggercmd.com/api/run/triggerSave?trigger=" + trigger + "&computer=" + computer + "&params=" + parameters + "&token=" + token);
              yield return www.SendWebRequest();
              if (www.isNetworkError || www.isHttpError)
                  Debug.Log(www.error);
              else
                  // Show results as text
                  Debug.Log(www.downloadHandler.text);
                  // Or retrieve results as binary data
                  byte[] results = www.downloadHandler.data;
      I created an example VR app for Oculus Quest to demonstrate. I recommend using SideQuest to install it.
