    Linux install without X-Windows
    5 Posts 3 Posters 1.9k Views 1 Watching
      This method installs the agent to run in background mode as root in a systemd daemon.
      sudo su -
      git clone https://github.com/rvmey/TRIGGERcmd-Agent.git
      cp ubuntupackage.json package.json
      apt install -y npm
      cd /root/TRIGGERcmd-Agent
      npm install
      node /root/TRIGGERcmd-Agent/src/agent.js --console
        (enter your token, then press CTRL-C to exit the foreground agent)
      /bin/sh /root/TRIGGERcmd-Agent/src/daemonmgr.sh --add /root/.TRIGGERcmdData
      systemctl enable triggercmdagent
      To edit your commands, edit /root/.TRIGGERcmdData/commands.json
      • K Offline
        kaligora
        How i can add triggers under command line?
          Russ @kaligora
          @kaligora, you have to somehow edit the commands.json file to add commands/triggers.
          • P Offline
            pirates
            Fourth line should be:
            I think that's how it download file.
              Russ @pirates
              Thanks @pirates. I just fixed it.
