    JAVA READ ERRO INSTALLATION TRIGGER
    11 Posts 2 Posters 2.0k Views 1 Watching
    • Raphael CazelattoR Offline
      Raphael Cazelatto
      i'm trouble 😞 Help me please
        Russ @Raphael Cazelatto
        @Raphael-Cazelatto,
        Also this might be a known problem. The TRIGGERcmd agent does not work on 32bit Windows. Only 64bit works.
        Please check your version.
        https://www.howtogeek.com/228042/how-to-switch-from-32-bit-windows-10-to-64-bit-windows-10/
          Raphael Cazelatto
          thanks for the answer ... but my system is 64! I don't know how to install it in folder 64 and not in x86
            @Raphael-Cazelatto, will you please type this in a cmd window, and tell me the result?
            echo %PROCESSOR_ARCHITECTURE%
            C:\Users\Russ>echo %PROCESSOR_ARCHITECTURE%
            AMD64
            I just want to confirm.
            The other thing I've seen cause this is certain antivirus software. You could try disabling that while you install the TRIGGERcmd agent.
              Raphael Cazelatto
              @Russ said in JAVA READ ERRO INSTALLATION TRIGGER:
              echo% PROCESSOR_ARCHITECTURE%
              the answer is AMD64, just like yours. And I don't use any antivirus. my windows defender is not activated too
                @Raphael-Cazelatto, this is a new one. Here are some options and things to try:
                • You could right-click the installer exe and click "Run as administrator".
                • You could try this version of the agent that was meant for 32bit Windows, but works fine on 64bit.
                • You could try uninstalling the agent and deleting the C:\Users\rapha\AppData\Local\TRIGGERcmdAgent folder, then re-install it.
                  Raphael Cazelatto
                  • the first alternative I had tried a long time ago and it didn't work.
                  • this second I tried earlier today, with your link, however, the result is the photo
                    -i uninstall my programs with "revounnistall". it automatically deletes all folders after uninstalling
                  the photo shows the result installing node and unzipping the agent zip... i don't really know what to do anymore .. but i don't want to give up
                    Raphael Cazelatto
                    my profit does not appear same yours
                      @Raphael-Cazelatto, there should be more output after that command that ends with --console. It should prompt for your token, then connect to the server.
                      I wonder if the problem is the Á in your path, or maybe the spaces. Can you try without that? I'll do the same.
                      EDIT: Nevermind. I tested it on my computer in a folder with an Á in it. It worked fine for me.
                      PS C:\Users\russe\Downloads\folder with Á in it\triggercmdagent> .\triggercmdagent.bat
                      C:\Users\russe\Downloads\folder with Á in it\triggercmdagent>node "C:\Users\russe\Downloads\folder with Á in it\triggercmdagent\agent" --console
                      Daemon install: false
                      Logging in with saved token.
                      Checking if the 5f237c33191176001ad49abe computer exists.
                      (node:18616) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
                      Tokenfile: C:\Users\russe\.TRIGGERcmdData\token.tkn
                      ComputerIDfile: C:\Users\russe\.TRIGGERcmdData\computerid.cfg
                      Write backup completed.
                        |>    Now connected to https://www.triggercmd.com.
                              (using sails.io.js node SDK @v1.1.13)
                               Connected at: Sun Oct 04 2020 12:37:23 GMT-0400 (Eastern Daylight Time)
                      { message: 'Subscribed to 5f237c33191176001ad49abe!' }
                      Initiated command adds
                      Initiated command removals
                        Raphael Cazelatto
                        I do not know how to deal with this, I am struggling to install this program which should be simple ... when I double click on the file, the cmd appears quickly and already closes, I cannot edit the key. The only key I can edit is the photo. : /
                          @Raphael-Cazelatto, what if you open a cmd prompt first, then run that triggercmdagent.bat script?
                          Can you send me a screenshot of that?
                          I'm sorry nothing is working for you.
