    Unexpected token W in JSON at position 273
    5 Posts 2 Posters 1.2k Views 1 Watching
    • Jaxon TJ Offline
      Jaxon T
      I'm trying to get my computer to sleep on command.
      This is my command line
      "trigger": "Sleep",
      "command": "C:\Windows\System32\psshutdown /d /t 1",
      "ground": "background",
      "voice": "Sleep",
      When I tell it to run a java error pops up with "Unexpected token W in JSON at position 273" and when I write psshutdown \d \t 1 without the whole directory nothing happens.
      Thanks, Jaxon
        Russ @Jaxon T
        @Jaxon-T, I think I know why you're seeing that error:
        For proper json formatting, the backslashes in your command path need to be double-backslashes, like this:
        "command": "C:\\Windows\\System32\\psshutdown /d /t 1",
        • Jaxon TJ Offline
          Jaxon T
          After I did what you said it happened again except this time it said
          Unexpected token } in JSON at position 132
          the whole text command editor is just
          "trigger": "Sleep",
          "voice": "Sleep",
          btw i tried psshutdown with and without .exe at the end so the other text editor looks like
          "trigger": "Sleep",
          "command": "C:\Windows\System32\psshutdown.exe /d /t 1",
          "voice": "Sleep",
          • Jaxon TJ Offline
            Jaxon T
            btw when i copy and paste the text it takes away the double slash so these are double slashed!Capture.PNG
              Russ @Jaxon T
              @Jaxon-T, if you use three of these "back ticks" ` before and after your text, it will show it as a code block and keep any backslashes intact.
              Like this:
                "trigger": "sleep",
                "command": "d:\\tools\\pstools\\psexec -h C:\\\\Windows\\System32\\psshutdown.exe /d /t 1",
                "offCommand": "",
                "voice": "sleep",
                "voiceReply": "",
                "allowParams": "false"
              I tried your command and it didn't work because of UAC. You'll notice I ran it with psexec -h. That worked because it's running as a background command which runs it as Local System which has access to run things "As Administrator" with psexec -h.
