    Processing rate limit for multiple triggers
    • Raphael NevesR
      Raphael Neves
      Hi all, I have a routine defined on my Alexa to trigger two different commands through the IFTTT interface, but I had to schedule the second one to be executed 60 seconds after the first one. I read somewhere TriggerCMD defines a processing rate per consecutive requests.
      My question is: does the premium account have the same rate limitation as to the free account?
      The routine closes all my open apps, and after it triggers the sleep mode. As above-mentioned, I have to wait 1 minute between these two tasks to have my execution cycle done 😞
      Will the premium account solve my problem??
        Russ @Raphael Neves
        @Raphael-Neves, yes, if you subscribe you can run more than 1 command per minute.
