    Difficulty executing commands in the shell script
    4 Posts 2 Posters 764 Views 1 Watching
    • Alcir JuniorA Offline
      Alcir Junior
      Hello everyone I'm having trouble running some command lines in my shell script:
      #!/bin/sh
      # cd Cloud/laradock && docker-compose stop
      open -a mail
      open -a whatsapp
      open -a slack
      cd ~/Cloud/laradock && docker-compose up -d nginx mysql postgres mongo redis
      open -a google\ chrome http://dev.laravel.library
      code -n ~/Cloud/Dropbox\ \(Personal\)/Projects/Caju/PHP/Frameworks/Laravel/Library/
      open -a memory\ clean\ 2
      All lines that start with the open command execute normally, but the lines that I access a folder to run the docker-compose and the line where I execute the command to open a folder in vscode using the code does not work.
      Has anyone ever experienced this, thanks?
      • RussR Online
        Russ @Alcir Junior
        @Alcir-Junior,
        In the shell script you must not have all of your normal aliases and environments variables available, so you'll generally need to specify the full path to things. Like for vscode, this works:
        /Applications/Visual\ Studio\ Code.app/Contents/Resources/app/bin/code -n ~/Desktop
        Or this:
        /usr/local/bin/code -n ~/Desktop
        You can type this command to find the path for docker-compose:
        which docker-compose
          Alcir Junior
          Hello russ, thank you very much it worked perfectly.
          Thank you.
          • RussR Online
            Russ @Alcir Junior
            @Alcir-Junior, awesome.
