    How can I turn the computer screen on?
    Instructions
    1.5k
    • Marcos silvaM
      Marcos silva
      I've tried so many things but nothing works on windows 10 with Alexa only turn off the screen is working perfectly.
        Russ @Marcos silva
        @Marcos-silva, please confirm, if you use the website, it's working fine, it just Alexa that doesn't work? Also, not even the built-in calculator and notepad commands are working with Alexa?
        You could try the "turn monitors on" powershell command here, but success it depends on your hardware I think. It didn't work for me for example, even though turn monitors off powershell command did work. You'll see that the script that effectively presses the Print Scrn button did work to turn my monitor back on.
