    background service linux
    1.2k
    • frederico allanF
      frederico allan
      after install background service and close triggercmd agent, my alexia commands dont work.
      look my agent status:
      fred@NOTEBOOK:~$systemctl status triggercmdagent.service
      ā— triggercmdagent.service - TRIGGERcmd Agent
         Active: failed (Result: start-limit-hit) since Tue 2020-06-02 14:02:24 -03; 14min ago
        Process: 29520 ExecStart=/usr/bin/env node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
       Main PID: 29520 (code=exited, status=0/SUCCESS)
            CPU: 282ms
      Just woks with open agent or run this command:
      fred@NOTEBOOK:~$node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /home/fred/.TRIGGERcmdData
      Running Linux daemon to run background tasks.
      Tokenfile: /home/fred/.TRIGGERcmdData/token.tkn
      ComputerIDfile: /home/fred/.TRIGGERcmdData/computerid.cfg
      Logging in with saved token to run background tasks.
      Write backup completed.
        |>    Now connected to https://www.triggercmd.com.
               Connected at: Tue Apr 23 2019 18:29:36 GMT+0000 (UTC)
      Initiated command adds
      Initiated command removals
      { message: 'Subscribed to 5ace777f053a4600193464d1!' }
      { trigger: 'open-youtube', id: '5ace9eb5a2b3bd0019322655' }
      Running trigger: open-youtube  Command: google-chrome https://www.youtube.com;
      Reported: Command Ran
        Russ @frederico allan
        @frederico-allan, the background agent adds, removes, and runs background commands only, and the foreground agent adds/removes/runs foregound commands.
        Also background commands run as root in the background (no GUI) using the /root/.TRIGGERcmdData folder which is associated with a different computer object in your account if you ran the foregound agent as your non-root user originally.
        If you compare these two files, you'll probably see different computer ID's:
        /root/.TRIGGERcmdData/computerid.cfg
        frederico allanF 1 Reply Last reply Reply Quote 0
        • frederico allanF
          frederico allan @Russ
          @Russ tks for your attention.
          One Question: /root/.TRIGGERcmdData/computerid.cfg doesn't exists.
          root@NOTEBOOK:~/.TRIGGERcmdData# cat commands.json
            {"trigger":"Gnome Editor","command":"gedit","ground":"foreground","voice":"edit","allowParams": "false"},
            {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
          root@NOTEBOOK:~/.TRIGGERcmdData# cat debug.log
          Quitting
          root@NOTEBOOK:~/.TRIGGERcmdData# ls -al
          total 24
          drwxr-xr-x  2 root root 4096 mai 20 12:52 .
          drwx------ 20 root root 4096 mai 27 14:03 ..
          -rw-r--r--  1 root root  461 mai 15 09:53 commands.json
          -rw-r--r--  1 root root   49 mai 26 10:38 debug.log
          -rw-r--r--  1 root root  516 mai 15 09:53 sendresult.sh
          -rw-r--r--  1 root root  228 jun  2 14:02 triggercmdagent.service
          But exists in this folder ~/.TRIGGERcmdData/computerid.cfg.
            "trigger": "open-youtube",
            "command": "google-chrome https://www.youtube.com;",
            "ground": "background",
            "voice": "abrir youtube",
            "voiceReply": "open youtube",
          does any thing wrong with my instalattion?
            @frederico-allan, if you run triggercmdagent while logged in as root, it should create a /root/.TRIGGERcmdData/computerid.cfg file, and background service should use that. Just run triggercmdagent, then CTRL-C to exit.
            Also, it doesn't make sense to run google-chrome as a background command because you won't be able to see it.
            You want to run google chrome in the foreground agent. You run the foreground agent by running triggercmdagent in a terminal window in Xwindows.
            • frederico allanF
              frederico allan
              @Russ i got it now. tks a lot!
              in fact, I need start triggercmdagent on startup. thats the point of this thread, cause I thought that the wrong background installation did not start the trigger correctly.
                @frederico-allan, I wasn't able to program the foreground agent on Linux to startup automatically after login. I couldn't find a standardized way to do that. If you know of a way, please let me know.
                I'm glad you got it working.
