    Lock your screen Mac
    Scheduled Pinned Locked Moved Mac
    8 Posts 4 Posters 4.2k Views 1 Watching
    • Ricardo MachadoR Offline
      Ricardo Machado
      What is command lock screen?
      Tks
        Russ @Ricardo Machado
        @Ricardo-Machado, please try this command:
        /System/Library/CoreServices/Menu\ Extras/User.menu/Contents/Resources/CGSession -suspend
        I found that here btw.
          Ricardo Machado
          @Russ said in Lock your screen Mac:
          correct operation 😄
          • Italo RodriguesI Offline
            Italo Rodrigues
            On my Mac this command is not working. Anyone else with the same problem? Any new solutions?
            No meu Mac esse comando não está funcionando. Alguém mais com o mesmo problema? Alguma nova solução?
              Russ @Italo Rodrigues
              @Italo-Rodrigues, does it work if you run that command from a Mac terminal window? Please try that and screenshot the result.
              • Daniel GarciaD Offline
                Daniel Garcia
                hola,tengo el mismo problema que @Italo-Rodrigues
                lo ejecute en la terminal y no me funciono
                  Russ @Daniel Garcia
                  @Daniel-Garcia, I found here that Apple removed that CGSession binary in MacOS Big Sur, so please try this command instead:
                  osascript -e 'tell app "System Events" to key code 12 using {control down, command down}'
                    Daniel Garcia
                    Gracias,ya me funciono
