    How to run a .jar file on linux with TRIGGERcmd?
    2 Posts 2 Posters 482 Views 1 Watching
    • Pietro GonçalvesP Offline
      Pietro Gonçalves
      I'm trying to use the command "java -jar ./Documents/Test/main.jar", main.jar has a JOptionPane.showMessageDialog, but when I run it by voice it doesn't show the output on the screen.
      When I click the green button to run, it runs .jar, but by voice it doesn't.
      The command "amixer -q sset Master 100% +" is also not working, why?
        Russ @Pietro Gonçalves
        @Pietro-Gonçalves, do any of your commands work? I suspect the problem might be that you set the command to be a background command?
        If you do that, your commands will run in the foreground via GUI editor, and they'll run the background when you run them remotely. You also have to have the background agent installed for background commands to run remotely.
