    How can I shutdown PC?
    25.4k
      A Former User
      I have tried for an hour to get my computer to shutdown with triggercmd and Alexa. I cant figure it out. I can run calculator, but cant even run Reboot that was a default trigger that came with the program. I have windows 7. I have updated triggercmd, installed background service, and addd to system path. I have tried with GUI command editor, and text editor. Here is what the text looks like for calculator, which works, open website, which works, and reboot and shutdown, which dont work.
      "trigger": "Reboot in 10 seconds",
      "command": "shutdown /r /t 10",
      "ground": "background",
      "voice": "reboot"
      "trigger": "Calculator",
      "command": "calc",
      "ground": "foreground",
      "voice": "calculator"
      "trigger": "Launch a website",
      "command": "start http://www.google.com",
      "voice": "site"
      "trigger": "shutdown",
      "command": "-trigger "shutdown" -computer "pc"",
      "voice": "shutdown"
      Please help
        Russ @A Former User
        @rtubbs316, good question. I added this to the examples. I think others could use this too. I also added "Abort shutdown"
        This is the command assuming you want it to wait 60 seconds. Use /t 1 to shutdown in 1 second:
        shutdown /s /t 60
        You could also add a /f for "force"
        shutdown /s /t 60 /f
        You can also abort the shutdown like this:
        shutdown /a
        Type this at a cmd prompt to get the full useage of the shutdown command:
        shutdown /?
        C A 2 Replies Last reply Reply Quote 0
        • C
          Christopher Hogben @Russ
          @russ I'm also having issues using the reboot and shutdown commands. I've called my PC "computer" and so I've tried to ask Alexa both "Alexa, ask TRIGGERcmd to shutdown computer" and "Alexa, ask TRIGGERcmd to shut down in 1 minute computer".
          However, Alexa responds with "Could not find a computer with voice word shutdown in 1 minute." (same issue with rebooting also).
            Russ @Christopher Hogben
            @christopher-hogben,
            Assuming your voice field is set to "reboot", your sentence should be: "Alexa, ask TRIGGERcmd to run Reboot".
            If you have more than one computer and want to run a command on your non-default computer, you can say, "Alexa, ask TRIGGERcmd to run Reboot on Computer" to specify the computer.
            Also if you click the "Voice commands" link on the website while you're logged in, you'll see a list of sentences in the "Say this" column.
            Also, make sure you test this from the website first. If you don't see the "Reboot in 10 seconds" option on the website, you probably don't have the background service installed yet. Background commands only show up when you have the background service installed. Background commands are meant to be runnable even if you're not logged into your PC.
            • A
              Alpha Neuron @Russ
              @russ Sorry but Im new at this. Where do i find the screen to even type in "shutdown/s/t1" ? You seem to jump right into things but I cant even get on the same page. excuse my "newbie" status.
              • A
                Alpha Neuron
                OK, start by going to the tray icon, right click, and click on GUI command editor... right
                • A
                  Alpha Neuron
                  ok, so now the reboot command is on the gui command editor but it does not appear under the "actions" in my profile... step by step instructions are missing my friend, or are not obviously apparent to the newbie ie me.
                    Russ @Alpha Neuron
                    @alpha-neuron, I think the reason your reboot command isn't showing up is the background service isn't working on your computer or you didn't install it yet. You can use foreground commands, but you'll have to be logged in for them to work. That's not a problem for most people. So please just try switching the reboot command's Ground field to foreground instead of background.
                    • A
                      Alpha Neuron @Russ
                      @russ Thanks, I ended up changing to foreground.
                      • Ivan FreitasI
                        Ivan Freitas
                        How do I shut down my macbook, I tried to put these codes above but it didn't work
                          Russ @Ivan Freitas
                          @Ivan-Freitas, I posted a mac solution here in the mac section.
