    Config file keeps getting reset
      A Former User
      Hey all,
      I added some new triggers, but they keep getting removed. I've checked their format and they seem okay, but i might be missing something.
        {"trigger":"Shutdown PC","command":"ssh user@pc.local "shutdown -s -t 60"","ground":"background","voice":"Shutdown my PC","allowParams": "false"},
        {"trigger":"Restart PC","command":"ssh user@pc.local "shutdown -r -t 60"","ground":"background","voice":"Restart my PC","allowParams": "false"},
        {"trigger":"Hibernate PC","command":"ssh user@pc.local "shutdown -h -t 60"","ground":"background","voice":"Hibernate my PC","allowParams": "false"},
        {"trigger":"Sleep PC","command":"ssh user@pc.local "nircmd standby"","ground":"background","voice":"Sleep my PC","allowParams": "false"},
        {"trigger":"Abort PC","command":"ssh user@pc.local "shutdown -a"","ground":"background","voice":"Abort","allowParams": "false"}
      Console output of installdaemon.sh
      pi@pihole:~ $ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
      Daemon install: true
      Logging in with saved token.
      Checking if the 5e861xxxxxxxxxxxxx193d3fe6 computer exists.
      This computer was deleted from your account.  Login to recreate it.
         Active: active (running) since Sat 2020-04-04 12:23:29 BST; 3 days ago
       Main PID: 275 (node)
         Memory: 33.7M
                 └─275 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      Apr 07 19:04:38 pihole env[275]: Write backup completed.
      Apr 07 19:04:39 pihole env[275]: Initiated command removals
      Apr 07 19:04:39 pihole env[275]: Initiated command adds
      Apr 07 19:04:39 pihole env[275]: Failed while trying add a trigger.
      Apr 07 19:05:28 pihole env[275]: Failed while trying add a trigger.
      Thanks!
        Russ @A Former User
        @Lewis-S, I see two quotes in a row at the end of your commands. There should be only one.
        When the agent sees invalid json it reverts the file to the previous version.
          A Former User
          That makes sense.
          My commands need the quotes. Is there anyway of not needing to make scripts for each trigger?
          I read online somewhere about escape characters, but I'm not sure where I'd need them.
          Thanks
            Russ @A Former User
            @Lewis-S, to use quotes within quotes you generally have to "escape" them with backslashes. Like this:
            "She said \"hi\" to me"
              A Former User @Russ
              @Russ I see.
              It works, but the command is not working when it gets executed, as the ""s are being interpreted.
              I guess I'll have to use script files after all.
              Thank you very much!
              Edit: (split)
