    Script doesn't seem to finish running
      A Former User
      Hey,
      I've got a script that gets triggered by Alexa/Shortcuts/Button/QR etc, that disables my PiHole for an hour.
      I've got this script:
      # Combo of pihole-enable-delay and pihole-disable
      date
      pihole disable
      curl --data "param1=value1&param2=value2" https://maker.ifttt.com/trigger/pihole_disabled/with/key/b7GK*********-Z4lsit2o
      sleep 3600
      #sleep 10
      pihole enable
      curl --data "param1=value1&param2=value2" https://maker.ifttt.com/trigger/pihole_enabled/with/key/b7GK************-Z4lsit2o
      The runs for the first half, but seems to stop when it gets to the sleep command.
      Any ideas?
      Thank you
        Russ @A Former User
        @Lewis-S, what if you run that from a bash prompt while you're ssh'ed into the Pi?
        This is what I get:
        pi@pi:~ $ ./test.sh
        Fri  3 Apr 19:31:08 UTC 2020
        ./test.sh: line 2: pihole: command not found
        {"errors":[{"message":"You sent an invalid key."}]}./test.sh: line 8: pihole: command not found
        To confirm whether it's running the commands after the sleep, can you add a line like this to see if it creates the log file?
        echo Testing after the sleep > /tmp/log.log
        I did that and I get the log file, including if I run it via TRIGGERcmd:
        pi@garagepi:~ $ cat /tmp/log.log
        My commands.json entry looks like this:
        {"trigger":"testsh","command":"\/home\/pi\/test.sh","ground":"background","voice":"test"},
          A Former User
          Hi Russ,
          It runs fine if I run it from a prompt, but does seem to be getting caught up on the curls, which it has not previously.
          I'll have to look at that, I'm doing some network changes so that's probably not helping.
          log.log does seem to appear after running it via TriggerCMD.
          Thanks again!
