    Cant run commands on Raspberry Pi 3B+
    4 Posts 2 Posters 754 Views 1 Watching
    • rtn17R Offline
      rtn17
      Hi !
      I successfully setup my Raspberry Pi 3B+ but can't run any commands. My TriggerCMD is linked, too. Alexa is finding the "device" but when I run the command nothing happens. The original commands also didn't work for me.
      I want to control one LED Strip through Alexa. My config.json looks like following
        {"trigger":"strip","command":"sudo PYTHONPATH=".:build/lib.linux-armv7l-2.7" python rpi_ws281x/python/examples/strandtest.py -c","ground":"background","voice":"strip","allowParams": "false"}
      The path of the json file is /root/.TRIGGERcmdData/commands.json
      Thank you in advance!
        Russ @rtn17
        @rtn17 said in Cant run commands on Raspberry Pi 3B+:
        You need to escape the quotes (using backslashes) in your command because they're inside other quotes (for the json). Please try this instead:
          "trigger": "strip",
          "command": "sudo PYTHONPATH=\".:build/lib.linux-armv7l-2.7\" python rpi_ws281x/python/examples/strandtest.py -c",
          "ground": "background",
          "voice": "strip",
        rtn17R 1 Reply Last reply Reply Quote 0
        • rtn17R Offline
          rtn17 @Russ
          Thank you very much!
          I changed the command and added the absolute path.
            "trigger": "strip",
            "command": "sudo python /home/pi/rpi_ws281x/python/examples/strandtest.py -c",
            "voice": "strip",
          Now it's working.
            Russ @rtn17
            @rtn17, awesome. You're welcome.
