    X10 Batch files
    • J
      jbeckmantx
      Re: Could not find a command with voice word undefined
      I am receiving the same message when I ask for Google home to get TriggerCMD to run a batch file for X10. This happens only when it is an "on" command. All other commnds work fine. The "on" commands worked fine as well .. then stopped with no change from me. All of the batch files work from the TCMD web page as well as executing directly from the PC. It seems to be only when I am using Google home. Strange that it worked before but now will not ... and the off commands for the same X10 devices work fine.
        Russ @jbeckmantx
        @jbeckmantx, using the word ON with the normal google action ( as opposed to the newer TRIGFERcmd Smart Home action) has often been a problem because the word ON is used as the delimiter between the trigger name and the computer name (calculator on downstairs). I've tried to train Google's AI to handle that but it's still an intermittent issue.
        If you haven't tried the TRIGGERcmd Smart Home action, you really should. That's the best solution for thing you turn on and off.
