    Some suggestion about TriggerCMD
    • K
      killwa91
      Hello forum,
      I'm new to TriggerCMD and I love the idea and the product. Here are some suggetions and question based on my one day expericen. I hope this could make triggerCMD better.
      The suggestion is about account, triggerCMD account and forum account is different! If you can combine them be a single account, that will be much easier.
      The problem I have is about PATH. I'm using mac for TriggerCMD and I realized that you can only run commands from /bin. I'm not able to run command that installed from brew or customer scripts I put in /usr/local/bin. I have to copy the execute file to /bin to make it work. Could you add or give users access to modify the PATH for triggerCMD
      Thanks
        Russ @killwa91
        @killwa91, have you tried specifying the full path to your scripts or executables?
        So instead of your command being:
        myscript.sh
        Make it:
        /usr/local/bin/myscript.sh
        Also, about the forum having a separate account - I didn't write the forum software. I just installed and configured it, so it would be very difficult to do that integration.
