    Run bash / .sh file
    1.1k
    • Josiah RichardsJ
      Josiah Richards
      Hi! I'm running Windows 10 Pro.
      How can I run a bash command and .sh script?
      Manually, I open cmd,
      -cd to the directory
      -bash via WSL ubuntu
      -Then run sh script
      Is there a straightforward way to achieve with TriggerCMD agent?
      Best
        Russ @Josiah Richards
        @Josiah-Richards, I just tested this. I used vi to create a script called t.sh with only this line in it:
        echo Testing 1234.
        Then I ran the script with this command:
        bash t.sh
        • Josiah RichardsJ
          Josiah Richards
          @Russ said in Run bash / .sh file:
          bash t.sh
          Your amazing! Thank you VERY much!
          • RussR Russ moved this topic from Announcements on
