Installing and Upgrading the Linux agent on Redhat or CentOS
These instructions should work on Redhat, Fedora or CentOS.
Install the agent
Do this while logged in as your user (not root), in a Terminal window:
Run:wget https://s3.amazonaws.com/triggercmdagents/triggercmdagent-1.0.1.x86_64.rpm sudo yum install ./triggercmdagent-1.0.1.x86_64.rpm triggercmdagent
Upgrade the agent
Run:wget https://s3.amazonaws.com/triggercmdagents/triggercmdagent-1.0.1.x86_64.rpm sudo systemctl stop triggercmdagent sudo yum reinstall ./triggercmdagent-1.0.1.x86_64.rpm sudo systemctl start triggercmdagent
EDIT 11/21/2023:
If you find that the TRIGGERcmd Agent's icon doesn't show up, you probably need to install one of the Gnome shell extensions like this one: https://extensions.gnome.org/extension/615/appindicator-support/
You can install the "Extension Manager" app first, then search for that extension. -
T tuicemen moved this topic from Instructions on
R Russ pinned this topic on
