    unable to install - dependencies not met (ubuntu 19.04)
    6 Posts 3 Posters 2.4k Views 1 Watching
    • J Offline
      jasoncollege24
      in the repo for ubuntu 19.04, the libgconf2-4 package was renamed to libgconf-2-4
      Since triggerCMD depends on libgconf2-4, it's ignoring the already installed libgconf-2-4, and I can't install the other in this version of Linux.
      Is there an easy way to address this issue?
        Russ @jasoncollege24
        @jasoncollege24, thanks for reporting the problem. I'll need some time to install an Ubuntu 19.04 VM to reproduce the problem so I can figure out the best way to solve it.
        EDIT: I see the problem. I'll try to have a new .deb file available this weekend.
          @jasoncollege24, I updated the .deb installer. Now it installs libgconf-2-4 or libgconf2-4 depending on which one is appropriate for your specific Linux OS. Please download and try it again.
          https://s3.amazonaws.com/triggercmdagents/triggercmdagent_1.0.1_amd64.deb
          Also, thanks again for reporting the problem. I need to start watching for and testing the latest Linux releases so I can discover these issues before users do.
          • Spiritus UmbrarumS Offline
            Spiritus Umbrarum
            Ubuntu Studio 23.10> None Of libconf-2-4 Or libconf2-4 Are Found.
            Spiritus UmbrarumS 1 Reply Last reply Reply Quote 0
              Spiritus Umbrarum @Spiritus Umbrarum
              Solution>
              https://2h3ph3rd.medium.com/how-to-install-libgconf-2-4-on-ubuntu-23-10-fec6bda8d5f5
                Russ @Spiritus Umbrarum
                Thanks @Spiritus-Umbrarum. I'm working on updating the TRIGGERcmd .deb linux installer so it won't depend on libgconf-2-4 or libgconf2-4 anymore, but thank you for sharing the work-around in the meantime.
                EDIT: I updated the Ubuntu agent so it no longer requires libgconf-2-4.
