    Losing letters in words!
    • A
      Atmosphere
      I have a server running for over a year pretty much without issues on a raspberry pi
      Recently some of my commands sent, seem to lose letters
      When I say to Google home (like I've always done), "switch on the pool" and saved as a routine with wording "Ask triggercmd to run enable pool on server"
      It can't find that command on the server anymore!
      The reply is: "Could not find a command with voice
      word enable poo on server."
      This is gradually happening to all my commands, don't know where to begin, how do I fix this ???
      • A
        Atmosphere
        I renamed the trigger to "allow poo" (without the L) and now it works again... weird.This is the trigger:
        {"trigger":"poolon","command":"/home/pool_On","ground":"background","voice":"enable poo","allowParams": "false"},
        • A
          Atmosphere
          I went into GA routine, and changed the word "pool" with 2x Ls (pooll)
          "Ask triggercmd to run enable pooll on server"
          now it works again... what gives??
            Russ @Atmosphere
            @atmosphere, I'm thinking Google Assistant's AI is learning bad lessons (for your use case). It apparently thinks it's more likely you said poo than pool now. Your two solutions are good ones - poo is what it thinks you said, and pooll can't be mistaken for anything else.
              Russ @Russ
              @Atmosphere, I just found out this problem was on my end. There was a bug in my logic that triggered in cases when Google sent the computer word along with the trigger voice word. I'm sorry! Anyway I fixed it, so you might need to switch back to using pool instead of poo or pooll.
              Also, thank you for reporting it. I feel bad that I blamed this on Google when it was my fault.
