    Run the TRIGGERcmd linux agent in a Docker container
    Linux
    1.0k
      Docker provides a quick and easy way to package and run Linux software. This also works on Windows if you run Docker on Windows.
      Here's how to build and run a Docker container that runs the TRIGGERcmd agent:
      Create a text file called Dockerfile with these contents:
      FROM ubuntu
      ENV DEBIAN_FRONTEND=noninteractive
      RUN apt-get -y update && apt-get -y upgrade
      RUN apt install -y nodejs npm wget
      RUN wget https://s3.amazonaws.com/triggercmdagents/triggercmdagent_1.0.1_amd64.deb
      RUN apt install -y ./triggercmdagent_1.0.1_amd64.deb
      CMD node /usr/lib/triggercmdagent/resources/app/src/agent.js --console
      To build the container image, cd to the directory where you put the Dockerfile file, then run this command:
      docker build . --tag=triggercmdagent
      To see your new Docker image in your local Docker cache, run this command:
      docker images
      To run your new image on Linux and use /tmp as your TRIGGERcmd data folder, run:
      docker run -it -v /tmp:/root/.TRIGGERcmdData triggercmdagent
      To run your new image on Windows and use c:\mydir as your TRIGGERcmd data folder, run:
      docker run -it -v c:\mydir:/root/.TRIGGERcmdData triggercmdagent
      When you run it, you'll see it prompt for your token (from the Instructions page):
      Daemon install: false
      prompt: token:
      EDIT 3/28/21: I improved the docker container and published the code here:
      https://github.com/rvmey/docker-triggercmdagent
