This allows you to set the volume to whatever you want,
by using "ask Trigger cmd to run Volume (ON Computer Name) with parameter (Volume Level)"Parameter, when executed, is optional execution deflates to mute volume or unmute volume.
Trigger: Volume
Command: wscript "C:\Users\USER NAME\Desktop\Volume.vbs"
Group: Foreground
Voice: Volume
Voice Reply: ok setting Volume
Allow Parameters: true (IMPORTANT)
File Name: Volume.vbs
File Code:
Set WshShell = CreateObject("WScript.shell")
Dim Args, Var1
Set Args = WScript.Arguments
if wscript.arguments.count > 0 then
Var1= Args(0)
Var1= Var1/2
Var1= Var1-1
else
Var1= 0
end if
if Var1 = 0 then
WshShell.SendKeys(chr(173))
else
for i = 0 to 49
WshShell.SendKeys(chr(174))
next
for i = 0 to Var1
WshShell.SendKeys(chr(175))
next
end if -
hi, i can't make working.
não consigo fazer funcionar, podem me ajudar
