    Run a Jenkins job
    Linux
    1.2k
      Thanks to @muvvala-g for this idea.
      1. Download the jenkins-cli.jar file with this command:
      wget http://localhost:8080/jnlpJars/jenkins-cli.jar
      1. Setup a TRIGGERcmd command that runs your Jenkins job with a command like this:
      java -jar jenkins-cli.jar -s http://localhost:8080 -http -auth admin:PASSWORD build MyJob -v -s
      If your Jenkins server uses HTTPS, then change the URL accordingly, and remove the -http parameter.
      Using TRIGGERcmd for this is more secure than this approach because there's no need for an in-bound port on your firewall pointing to your Jenkins server.
