    Trigger to enter pin on login
    • V
      VeepuEco
      I already set up my Google Home and Alexa to turn on and off my PC. I have a pin setup on my PC but when I am away from my computer and in no way able to enter the pin, it gets stuck on there. Is there a way for me to tell my Google Assistant to trigger the pin, as if I am pressing the pin/password on the PC?
      Thanks.
      RussR F 2 Replies Last reply Reply Quote 0
        Russ @VeepuEco
        @veepueco, I don't think that's possible. You can still run commands while the screen is locked, but you won't be able to see the result until you manually unlock the screen.
        • F
          FlipeSilva @VeepuEco
          @VeepuEco try this example: https://www.pcworld.com/article/3100057/how-to-remove-your-login-password-from-windows-10.html
          i use this. the computer have password, but when you lok the pc and need to unlok you need to put password.
          but on start you don't need to put password. so if you have this option on and when talk with google assistent to power pc on, the pc enter on windows without password
          in my case but i dont know how to setup my google home to turn on my pc
          ps: sorry my english. i dont talk and write english very much
