    Install from github repo?
    7.6k
      Russ @stevef9432203
      @stevef9432203, please confirm - your commands.json stays when the router reboots, but your token.tkn file and computerid.cfg file go away? If so that's odd because the agent doesn't keep those two files open - it just reads them during startup.
      • S
        stevef9432203
        Yes the commands.json files stay intact. I will move content startup directory to hard disk storage to test. Can I specify the path to the data directory with the '--run' path prefix ?
          Russ @stevef9432203
          @stevef9432203, no, but you could change this line to set your "homedir" to something else.
          homedir = (process.platform === 'win32') ? process.env.HOMEPATH : process.env.HOME;
          Or maybe you could symlink your ~/.TRIGGERcmdData folder to a path on your hard drive.
